Hold a keystroke keep a preset active, releasing it disable the preset
Hello, this sound like something quite impossible to do. Is there a way to hold shift to activate a preset but not for as long as holding shift ?
How long do you want to hold it? You could use a timer to de-activate the preset at a given time after holding shift.
I read my post again and it made no sens. What I meant is :
I want a preset to be activated as long as I hold shift
I want the preset to deactivate as soon as I release shift
This should give you what you want.
Translator 0.3 will activate the preset ‘Shift’ when the shift key pressed.
Translator 0.4 will deactivate it when the shift key is released.
Shift-Preset.bmtp (1.5 KB)
I forgot that we can have a key down and key up as trigger … this software really continue to amaze me everyday
thank you
