Hold down note
Hi, I can’t find this answer here.
I’m trying to convert two things: A note on channel 8, output channel 15. (So I have to use MTP for this, instead of simply linking the notes to the daw). This is working fine.
The second thing I’m trying to do is trigger an ADSR envelope. So when holding down the note, keeping ‘note on’ active, then when I release the note it sends a ‘note off’.
Currently, I push it and it’s stuck on note on. I’m struggling with the two translators, second one for note off.
Two translators
Incoming: Note On MIDI CH 8 note 10 any value set to qq
Outgoing: Note On MIDI CH 15 note 10 value qq
Incoming: Note Off MIDI CH 8 note 10 any value set to qq
Outgoing: Note Off MIDI CH 15 note 10 value qq
You didn’t indicate the note number so I just added note 10 as an example.
Excellent. I didn’t even see the ‘note off’ drop down. Never used it before.
Sorry again to have to ask you about everything, but after 20 minutes of research, I begin to think this puzzle is beyond me.
Great tech support, Mr. Caldwell. :slightly_smiling_face:
I’m happy to help!
