Hi, i want to use my Bome Box as a Ethernet Master and still using my WIFI.
I have followed the instruction that i found in a similar post, but i can’t follow passage number 4 because i can’t find that menu.
I’m on firmware version 1.5.4
I have followed these steps
- Clean all network MIDI connections: click Disconnect in Bome Network and for all, and the same on the Network MIDI web config page.
- BomeBox WiFi: client to your WiFi router
- BomeBox Ethernet: direct cable connection to Mac.
- Preferred way is to configure as “Ethernet Master”. To circumvent the IP address conflict with your WiFi router, use Advanced Config to set IP to 192.168.2.1 (as shown above).
But i can’t find this menu tab
4. Bome Network on Mac, version 1.4.2 beta (or later): go to Settings → Network Settings → Excluded Networks. Click the + button and select 192.168.1.255. This is your WiFi network.
Thank You For Anybody Help
