But now I am kind of overwhelmed because I don't quite understand the instruction. Until this point I never did any kind of Midi configuration. I just used presets and stuff like that. If someone ever used two AKAI APC minis for MA dot2OnPC or similar, it would be awesome if you could help me.
Maybe someone has the time to describe what to do (for beginners ^^)
Hi, since I posted th original post, I found that unlike GrandMA2 dot2OnPC only allows for one MIDI channel, so although you can use 2 APC MINI's for on dot2, you will be restricted to 128 notes 0-127 because dot2 does not recognize multiple MIDI channels like GMA2 does.
Since each APC MINI has 90 controls (64 rectancular buttons, 16 round buttons, 1 square button and 9 faders), we have total of 180 controls for 2 APC MINIs, so you have 52 additional controls that you won't be able to use.
Since dot2 does not allow for multiple MIDI channels, the strategy will need to be changed by changing the note numbers on the second APC MINI. For faders, of course, we need to convert to notes. If you can tell me which controls you want to use on both devices (up to 128 total), I can post something to start with.
For backward compatibility, I recommend you keep your first APC MINI mapped as is and then only use an additional 38 controls on your second device 90+38 = 128. The easiest mapping for the second device would be the recangular buttons on the grid.
dot2 does not accept more than 128 Midi signals? That's sad okay.. Than I will probably just sell my second Apc mini. Its obviously not worth it to use it for only 30 buttons.
Maybe I'll find a similar midi controller with less buttons
We can route both APC MINIs into Bome MIDI Translator Pro and then either send them to a single output on separate channels to D-Pro or if D-Pro accepts it, just map each to separate ports to D-Pro. The value of MT Pro would then be just that of controlling LED feedback since it doesn’t look like D-Pro will handle this.
