Hi there, I have a williams allegro 3 with a connected sustain pedal and was wondering on how to make the pedal perform a keystroke on my PC. (key being spacebar). I also want it to hold the key when I’m holding the pedal down. What would be the input for the sustain pedal?
Hi and welcome to the Bome Community!
A sustain pedal down is usually CC64 with value of 127.
Up is CC 64 with a value of 0.
The attached should do the job.
Sustain-to-Keystroke.bmtp (1.1 KB)
You will likely need to define you incoming MIDI controller in the project file.
thank you!!! you’re amazing!
My pleasure!
