How to uninstall Bome Network and Cache DATA
I have been having an ongoing problem connecting two MacBooks together with Bome Network 1.60. Even if I set the Network Name in Network settings to something other than the default, it will change back later to a previous setting. I think something may be corrupted in Bome Network where that information may be saved or something else.
I want to un-install the Bome Network program on both machines and delete any associated files and then install from scratch to start fresh. How best to do that and find and delete any associated files?
Thank you.
Randy Getsla
Please refer to this post where you can find the Bome Network Settings. You can uninstall Bome Network and then remove the files before re-installing.
Thank you for the quick response. Always the best support!
