Hello. I am very new to this and wanted to know if it was possible to use this to play games such as minecraft and if so then how.
Probably not as a game controller is quite different than a keyboard. We may be able to emulate certain keystrokes but other joystick related controls would be something we wouldn’t be able to do. If all you want is WASD, maybe there is a chance for that.
Would you happen to know how to get the bome translator to work in the game? Like would I need a mod to make it work or would I have to play around in the game files?
Hi, you can experiment with it with the free trial copy of Bome MIDI Translator Pro. It is fully functional but times out every 20 minutes. You would be converting MIDI to keystrokes for use with Minecraft. You would need to ensure Minecraft is the focused application when running the game.
what does ‘make sure minecraft is the focused application’ mean and how would I do that?
Just make sure that you are on the MineCraft window while you are sending keystrokes.
