How to view realtime BomeBox log
I have opened the log in the Web Config (192.168.153.1) and the log menu only shows some specific information. I am looking to confirm both input and output translation is correct, without the use of BMTP.
I am also able to view the log in Bome Network, but only if a specific routing is active. It is not showing the proper output.
The BomeBox Log is not realtime and some messages may not be shown. If you use the “log” rule in rules, then that line should be shown but you might have to refresh the browser.
I usually redirect the output back to a PC and then use either MT Pro or SendSX to see the result. (Loopback type of logging)
