Hello
I would like to assign two different keyboard shortcuts on the same note input, but depending on the velocity of the “note on”.
For instance, I would like to have a “Ctrl X” if I strike the note softly (velocity below 40) and a “Ctrl C” if i strike it rapidly (velocity above 100)
Thank you for your help.
Welcome to the Bome community!
Please find the attached example.
There are 2 translators,
The rules in the first translator ensure it only fires if the velocity over 40
if qq>=40 then exit rules, skip Outgoing Action
The rules of the second translator ensure it only fires if the velocity is over 100.
if qq<=100 then exit rules, skip Outgoing Action
If it is in between, nothing will happen.
keystroke-depending-on-note-velocity.bmtp (1.4 KB)
Hi Steve
Thank you very much for your help
It looks like it is working fine…
I would like now to add a third rule
if qq is >=40 AND qq is <100
so I can trigger a third command
How would you do that ?
Thank you again …
Best regards
Something like this should work.
if qq<40 then skip next rule
if qq<100 then exit rules, execute outgoing action
exit rules, skip outgoing action
For other examples see this post under tips and tricks.
