Hi. Im about to buy midi translator pro and have a question if the following is possible.
I have a Platform M+ and want to use first 4 motorized faders for Midi CC Messages and the other 4 motorized faders to control the Send volumes for a selected track in my daw (currently reaper , but almost every daw can handle mackie sends´)
Yes, depending on the capability of your DAW. We can send and receive different faders information to different MIDI ports. These ports can be monitored by the same application or different applications. It is likely that you will need to add some translation to and from the Mackie MCU protocol depending on what the Platform M+ can do. Essentially it can make a controller look like two separate controllers by using Bome MIDI Translator Pro send and receive different messages to different MIDI ports.
