Hi all,
Is there a way to set up access to the internet and bomebox network to work simultaneously using only wifi (no ethernet)?
Currently i have two networks and i jump back and forth between them and its quite cumbersome.
Hi all,
Sure, set up your BomeBox as a WiFi Client using the SSID and password of your home router. Have your Computer also set up as a WiFi Client using the SSID and password of your home router. You home router will assign addresses to both devices using DHCP and they will be on the same network.
You can use the Bome Network tool to open the BomeBox web page in a browser.
