I’m using Mixtrack Pro (Numark) on Rekordbox 5. I’m completely new to BMT.
What I would like to do is use my normal mapping and have another virtual mapping which will allow me to use my 2 encoders in the correct operating direction and perhaps even later to use the jogs
Here is my basic configuration. Rekordbox sees the virtual port well
INCOMING:
Midi Message / RAW MID SYSTEM EXCUSIVE
F0 6C F0
Are these Raw Midi settings good?
What should I put in the rules now?
Thank you in advance for your response and analysis.
Sincerely
Finally I managed to get by.
I even managed to get the Jogwhells to work
Here’s what I’m trying to do, so far I haven’t found it.
I would like to map 3 functions to a button:
1st press - Display of HOTCUE
2nd Press - PAD FX display
3rd press - Beatjump display
4th press - I return to the HOTCUE
It seems to me that I need to make modifiers to the rules
Thank you very much
I managed to create what I wanted to do thanks to you
I just modified
if ga>3 then ga=0 ------- if ga>2 then ga=0 (3 positions)
I think I explained myself wrong the first time, sorry.
then I made a copy and paste by changing the MIDI note for deck 2 of the RKB software and I just changed the TT values (be careful, some values can conflict, duplicate)
