First of all, many thanks to Bome and the developers for creating this incredible software. Within minutes I was able to program something for Ableton and a MIDI pedal I had lying around that would have been impossible to do otherwise.
My only question is this, is it possible to keep the Translator Pro program active even if it is not the active window? As far as I can tell, whenever I click on Ableton, the MIDI functions stop working - only when I click back on the Bome application, then the MIDI functions start working again.
Here is the text for my project, in case this helps:
Project: asdf
Project MIDI OUT ports: IAC Driver Bus 1
Route #1: IN “Bome Virtual Port 1” → OUT “IAC Driver Bus 1”
Preset 0: New Preset
Translator 0.0: New Translator
Incoming: Keystrokes: Page Up
Outgoing: Control Change on ch. 1 with CC#:64 (0x40) and value:127 (0x7F), to ports Bome MIDI Translator 1 Virtual Out, IAC Driver Bus 1, Bome Virtual Port 1, delay:20 millisec
Translator 0.1: New Translator
Outgoing: Control Change on ch. 1 with CC#:64 (0x40) and value:1 (0x01), to ports IAC Driver Bus 1, Bome Virtual Port 1, Bome MIDI Translator 1 Virtual Out
It appears your translators have incoming keystrokes and outgoing MIDI messages. My guess is that it is working OK, however for incoming keystrokes, they are never suppressed so that page up and page down commands are also getting sent to the currently in-focus application as well as the MIDI messages. It is best if you set up your incoming keystrokes for something that no applications are looking for. Maybe some unused keyboard shortcuts or better still, invest in a low cost MIDI controller that will not send keystrokes at all?
