Is there a way for midi translator to tell what application is active
I’d like to have multiple setups for Midi Translator and switch between them depending on what application is active.
Example:
I have one application that uses MIDI commands.
I have another application that uses keystrokes.
I’d like to use my Touch mini control surface in both applications.
By the way I love the app and I’m very grateful for all of those example files you’ve created. Thank you.
Yes there is an incoming trigger to determine if a given application has focus.
For MIDI applications, they don’t need to have focus but you could use that trigger from the application to disable MIDI if you are focused elsewhere. You could enable and disable given presets to do the switching.
Steve, you are an amazingly technical person with remarkable logic skills, I’ve been reading many of the advice suggestions you’ve offered people… Thank you very much…
