It is on the network cause it finds my other machine. I’m doing computer to computer. But it can’t connect because I cannot figure out how to enter the Pro License Key in because the UI doesn’t come up on the Mac? I click the Bome icon and Show and get nothing? I must be missing something simple. Thanks. Thomas
Sorry you are having troubles.
I’m on Ventura 13.6.1 and it works. Perhaps you should check your Privacy and Security settings and then Accessibility then make sure you add Bome Network there.
Bome Network should show in your top menu bar and you should be able to click on it and the click on show.
I’ll give it a try later this week. I’m part time at my church so not always onsite.
OK, let me know.
