i would like to be able to use the “option” on my mac keyboard + a BMT pro mouse command …?
Translator : Option Down
Incoming: Keystroke Option Down
ga=1
// End of Rules
Outgoing: None
Options: N/A
Translator : Option Up
Incoming: Keystroke Option Up
ga=0
// End of Rules
Outgoing: None
Options: NA
Translator :MIDI Message
Incoming: Note On MIDI CH 1 Note 0
if ga!=1 then exit rules skip outgoing action
// End of Rules
Outgoing: Mouse click at 100,100
Options: Swallow
The first translator sets ga=1 when you hold down the option key. The second translator sets ga back to 0. The third translator sends the mouse message but only if the option button is down (ga=1).
Outgoing keystrokes are never suppressed.
You are the best !
