My controller keyboard - an Akai MPK249 is no longer detected by the BomeBox network.
When I plug it directly into my computer, Device Manager, and MT can see it - and it operates as intended with my DAW, but it doesn’t appear on the Bome network while plugged into the computer, nor when plugged back into the USB hub connected to the BomeBox.
I’ve tried different cables, USB ports, power cycling - you name it, but it’s not showing up like before.
Now I see the below screen. I turn on visibility to my WORLDE easy control that is attached to the gaming PC by clicking the switch until it turns green
Thanks for the input - I’m back up and running. It appears that my controller for whatever reason, ceased to show up on my powered USB hub and it took some dogged persuasion in Windows to get it back on there.
