Using Bome MIDI Translator Pro is it possible to set a keystroke down (for example, shift down) to send a CC note with a value of 127, and send the same CC note with a value of 0 on keystroke release/up (shift up).
I am trying to utilise a momentary USB keystroke pedal for talkback functionality. So on press down a CC note is sent, and then again on release.
Yes, this is possible. I have attached an example with two translators. The first one sends CC 0 value 127 when you press shift and he second one sends CC 0 value 0 when released. Keep in mind that the original keystrokes are NOT suppressed.
Create another translator with the same incoming action and different cc output
Using One translator use Raw MIDI for example B0 00 7F B0 01 7F
This would output CC0 MIDI CH 1 value 127 and CC1 MIDI CH 1 values 127.
7F is the hex value for 127
