Hi everyone
I’m trying to control the line 6 helix native plug-in with a midi controller but I don’t understand how to configure the midi translator pro program
Is there anyone who has used it and can help me??
the midi controller sends simple program changes that I have to convert into a control change 69 followed by a number from 0 to 7 to change the snapshots
I use Reaper as a DAW
I don’t have a Line 6 Helix Native but from what you describe, it should work with the attached.
First of all I set up my aliases as follows. You will need to set them up at the prompt to point to your actual MIDI device or application ports.
At the preset level, I set up my device selection as shown here.
I have one translator that takes any incoming Program Change on MIDI CH 1 with any value (set to variable qq).
The output is CC 69 with the same value (variable qq)
I add one rule to make sure the Program change stays less than or equal to 7
if qq>7 then exit rules, skip outgoing action
Here is what the MT Pro log window spits out if I set up to monitor MIDI IN and MIDI OUT.
624456 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 00
624456 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 00
624456 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=0
624459 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 01
624459 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 01
624459 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=1
624459 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 02
624459 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 02
624459 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=2
624460 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 03
624460 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 03
624460 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=3
624460 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 04
624460 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 04
624460 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=4
624463 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 05
624463 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 05
624463 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=5
624466 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 06
624466 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 06
624466 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=6
624466 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 07
624466 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 45 07
624466 - OUT 0.0 Control Change on ch. 1 with CC#:69 (0x45) and value:qq=7
624466 - MIDI IN [Bome MIDI Translator 1 Virtual In]: C0 08
624466 - RULE 0.0:1 condition satisfied: if qq>7 then exit rules, skip Outgoing Action
And the project file I used.
PC to CC Helix.bmtp (1.1 KB)
Good luck!
Hi, you have to set your Helix plugin to receive MIDI from Bome MIDI Translator Virtual 1 (BMT 1) instead of your controller. Then it should work.
