Will Midi Translator Pro do everything that the LoopBe products do?
C
C
If I remember loopBE is simply a tools for creating MIDI pipes.
Bome MIDI Translator Pro can create up to 9 virtual ports and you can use its router to provide similar routing. Unlike LoopBE, the ports named by Bome MIDI Translator Pro have fixed names so you cannot create your own names.
In addition Bome MIDI Translator Pro can also handle complex translations of MIDI messages which I don’t believe loopBE can do.
Bome also has Unlimited Named MIDI ports which is a paid add-on to free Bome Network. With that you can do more complex routing than loopBE offers but with no MIDI translation. You can route inputs to outputs, outputs to inputs etc and can also either split or merge MIDI signals. Like LoopBE you can provide your own names.
You can download a trial copy of Bome MIDI Translator Pro here. It is fully functional but times out every 20 minutes.
