Hey folks, I've been working on using MT Pro to provide Mackie Emulation on some controllers that do not have built-in Mackie Mode.
So far I've got some Mackie emulation capabilities for the following controllers:
Worlde EasyControl.9
Akai APC40 MKII
Nektar Impact LX25+
Novation Launch Control
If you have one of the above controllers, I can provide the Bome Project to you at a pretty decent price.
If you have another controller type that you want Mackie Emulation where there is none, but want to improve on the current Mackie Emulation with MT Pro, then I'm available for fee based programming/consulting.
The emulation I've created all has fader and V-POT and bank up and down functionality. If the controller has LED feedback, it also provides for indicators for solo, mute, select, record/arm V-Pot ring. Mileage for other functions vary depending on available knobs, buttons etc of the native controller. Most controllers do not have Mackie Display but if you load up MIDI Tools on your PC, you can forward these display message through Bome to see those as well using the MIDI Tools "Mackie Display" feature.
The benefit of having this is you can basically use your non-Mackie controller plug-and-play with any applications that support Mackie. I've tested the above with Ableton Live, Reaper, Cakewalk by Bandlab, BitWig and Davinci Resolve.
Just reach out to me at the email address below:
I’ve just tested the LaunchControl Mackie implementation with FL Studio 12 and Studio One 3 as well. I use 7 out of the 8 factory layers available to handle different mixer functions with the same 8 buttons. The lower knobs act as faders, and the upper knobs act as V-Pots. I use the left and right up and down arrows for navigation of factory template 0. Left and right handle bank select in factory template 1. Up handles a shift function so I can go one channel right and left in factory template 1. Also up handles various shift functions in other factory templates (like for re-centering the V-Pots). I have yet to see anyone make this little controller handle as much as Mackie implementation of most controllers their size and cost.
It is really a nice little controller in Mackie mode.
I’m now looking into what I can do with my Novation Launchkey MINI. It has an “undocumented” HUI mode but is quite limiting and also the Ableton implementation only can use the knobs for instrument control. I think with a little work I can have it doing almost as much as my LaunchControl It has 8 more pads but 8 less knobs so I would probably need to implement a shift function for the knobs. Also it doesn’t appear to have factor templates so I would need to emulate this in Bome presets.
Whoops also tested LaunchControl Mackie with Tracktion 7. I have the free (stripped down) version of most of the DAW’s than answer it so that I can better help users here.
The advantage of using Mackie Emulation is there is a lot less configuration setup with various DAW’s. Just use the Bome project file and go.
I now have my Novation Launchkey MINI working in Mackie Emulation Mode.
I use InControl to use knobs as either faders or V-Pots depending on the round button selection.
I have “takeup” feature on faders in case you change the volume on the DAW, The Launchkey MIDI won’t “jump” and will only work when it crosses the point that the DAW has set.
I use the track left and right buttons for bank left and right. I use the up button as a “shift” function so that the same track left and right buttons can also act as a channel left and right switch.
I use the up button as a shift button for fader 8. When held fader 8 will be master volume.
I use down button to control what the Pads send and display. press once and top row is Rec and bottom row is Select. If you press the down button, top row is Solo and bottom row is mute. Push down arrow button again and it toggles back to Rec and Select.
All standard keyboard features are unchanged. You can press InControl to turn off InControl mode and it acts just as if it were in “standard” mode.
It is amazing what you can do with Bome MIDI Translator Pro.
Hi. Not sure if you are still maintaining these emulations since last post in this thread was 5 years ago, but i am interested in porting one of these over to the monogram cc. Which one of these is closest to it you think ?
Isn’t the Monogram cc the controller that has a bunch of modules that you can magnetically piece together to create your own layout? If so, you could probably put together 8 faders, and 8 knobs and convert their messages to from CC’s for level and pan. Any buttons, you could convert note message for things like Solo, Mute, Sel and Rec arm. Since it is so customizable, you could probably start with any of the projects I created and modify it to your needs or you could search this forum and find some examples that you could build from.
The pre-packaged stuff, I charge for (as an independent consultant) but what is on the forum here is free. Maybe if you told me a bit more about your configuration and what it sends, I could put a basic template together with a few functions to get you started.
Hi
Thanks for the reply.
I plan to use it mainly for transport control specifically, the orbiter module since it can serve as a jogwheel (The top 5 most common uses of Orbiter) for scrubbing the timeline in cubase and at its center there is a ‘joystick’ which I was planning on mapping to both vertical and horizontal zooms.
So ideally the template would include ways for the MIDI CC from the orbiter to be translated to the appropriate Mackie equivalents and one translator for each of a button, fader and dial
Below is the requested information
I am also including information on the various elements of the modules and their behaviors (taken from the website) in case that helps
Slider - CC 102 on MIDI channel 1
my intended use is volume
info on behavior
MIDI CC – changes the assigned MIDI CC between 0 to 127
Dial - CC103 on MIDI channel 1
my intended use is panning
info on behavior
MIDI CC (Absolute) – Dials operate as potentiometers with min and max points, sending values between 0 and 127 on the assigned CC number
MIDI CC (Relative) – Dials operate as endless encoders, sending repeating values of 1 and 127 when turned right and left, respectively. This is also known as ‘Twos Complement’.
Monogram does not apply acceleration internally when used in MIDI CC mode. Please select ‘Linear’ mode in your DAW if applicable.
Button - CC104 on MIDI channel 1
my intended use is start stop playback (or record)
info on behavior
MIDI Note
MIDI CC (Momentary) – changes the value of the assigned CC number from an Off value (default 0) to an On value (default 127) when the key is pressed
MIDI CC (Toggle) – each press toggles the value of the assigned CC number between two values (defaults 0 and 127)
Orbiter ring - CC 101 on MIDI channel 1
my intended use is jogwheel - CW forward CCW backwards
info on behavior
Orbiter disc x axis CC 105 on MIDI channel 1
my intended use is horizontal zoom in (click right) and out (click left)
Info on behavior
MIDI CC – changes the value of the assigned CC number from a minimum of 0 to a maximum of 127, resting at 63 when the disc returns to center
Pitch Bend (14-bit output)
This output is upscaled as the physical resolution of Orbiter disc is 8-bits per axis (i.e. -127 to +127)
Channel Pressure (0 to 127)
Orbiter disc y axis CC 106 on MIDI channel 1
my intended use is vertical zoom in (click up) and out (click down)
Info on behavior
Thank you for this. Everything works as expected. One thing I noticed is that if I have more than one track in the project, and I try to move the volume fader on any selected track, it always changes the fader of the first track. I am guessing this is how Mackie works. It doesn’t know to affect the volume fader of any selected track just the first, second, etc track in the selected bank. Cubase 12 and up now has the MIDI Remote feature so I was thinking of leaving the jog wheel on Mackie and program the fader/pan through that
Also, can we combine inputs in MTP? Meaning can I push the shift key on my keyboard and turn the dial on the console so that the scrubbing is slower for example?
Right, Mackie MCU has no concept of ‘Currently selected Track’. If you have a couple of spare buttons, we could program them for next track and previous track and keep track (no pun intended) on which one we are on in MT pro and send out messages to the desired fader.
Hello
Thanks for the reply. i was able to solve the selected track situation with the MIDI remote feature of cubase while keeping the jog wheel on mackie
Is there a way to combine inputs in translator pro? Meaning can I push the shift key on my keyboard and turn the dial on the console so that the scrubbing is slower for example?
Potentially, however it depends on what your controller sends. If it is sending values greater than 1 (in each direction) we can put a translator together that changes it to 1 and then add a shift preset in the project file that would could be turned on and off with the shift key. If your dial only sends +1 or -1 then we can’t get any finer thatn that.
One functionality I would like to have is to slow down the rate at which the jog dial scrubs through the project when I press the shift key and to activate the vertical zoom only when I press shift so that I don’t accidentally hit it when I am zooming in horizontally. Is that achievable ?
I am trying to add more Mackie controls to the monogram but I don’t know what those messages are supposed to be… Is there a repository of the Mackie protocol somewhere? I noticed the translator output is raw data. Where do we get those from ?
Well your documentation indicates that it does not have acceleration so the only thing I could think of is to only send a message on 2-3 click of a turn in either direction. The amount moved would be the same for every click that gets through but there would be less clicks as you move the wheel.
Indeed you could have button to block any outgoing action when you push a button. You generally set a global variable (ga for example) to 1 and have a rule at the beginning of your rules that says
if ga>0 then exit rules skip outgoing action.
A note on (button push) and note-off (button release) could set ga to 1 and 0 respectively. (2 more translators). Or you could use a computer shift key if you are out of MIDI buttons.
The below link had a manual that is pretty good. Toward the end is where all of the MIDI messages are documented. This is primarily how I learned it but some vendors implement a bit differently.
hi
I started a new translator that I called ‘global shift key’ to capture my keyboard shit key but I can’t find where to assign it to the ga variable so that I can call it from the other translators …
Translator 0.0 will set ga=1 when note 96 button is pushed on MIDI CH 1
Translator 0.1 will set ga=0 when note 96 button is released on MIDI CH 1
Translator 0.2 will either send CC9 or CC10 while turning CC96 with whatever value C96 is. If ga=1 it sends CC10 if ga=0 it sends CC9.
