Hi chaps, can’t get Mouse DOWN AND UP to work, I am sending position too. Seems to “hold the button down”.
I have tried putting a 1 second delay between actions from translators, and breaking the actions up, still won’t work, please help.
Hi, assuming you mean mouse click up and mouse click down, I’ve included an example project that should work. There are two translators. The first clicks down when incoming MIDI Control Change (CC1) = 127 (button pushed) , the other when the button is releases CC1=0. I tested this on a Mac and it worked fine. If this is not what you want, please clarify and possibly post your project file so we can take a closer look.
Mouse-Click-Demo.bmtp (1.0 KB)
Right!
I see the fault in my implementation. Thank you! Solved.
Paul Elliott
FireStarter
065 980 9897
www.throwfirewoodatme.com
