How are we looking with the new update from Apple?
- MT Pro 1.9.1 is officially only supported up to MacOS 15
- Often, MT Pro works fine on a newer OS version.
- However, for mission critical systems, we advise to not update MacOS until all the software you’re running on it has officially declared support for that OS version.
Thanks.
Okay, after the couple of mission-critical shows, I’ve now updated macOS to Tahoe 26.0.1 and everything is still working smoothly.
Obviously, this is not to encourage other users to update, but for new users who don’t really have a choice but to start with Tahoe, this should be relieving to know.
I’m glad it is working for you as well!
