Manual Routing Change
Hi
Wondering whether if a BomeBox is running an MTP project there remains the option of using the web interface to change port routing?
I’d envisaged having MTP do some processing of incoming data to perhaps change channels and alter a few other minor things, and directing to virtual ports. Then via the web interface manually assign which physical ports is associated with a virtual port; this would likely change session to session, (i.e. a different synth).
Cheers
Routes and Aliases on BomeBox can be changed with the web interface.
For any Bome MIDI Translator Pro projects loaded, you can trigger hose actions with MIDI messages. You can even have your Bome MIDI Translator Pro project to change to a different project on the BomeBox.
