Mapping CCs to a list of many sysex strings
Hello all!
Been having fun setting up midi controllers to crack open the depths of my Roland JD-Xi, which has very limited cc implementation but very robust sysex potential!
one thing I am trying to implement is selecting from a list of around 450 drum samples with 4 cc knobs first value is: F0 41 10 00 00 00 0E 12 19 70 2E 23 00 00 00 01 00 00 00 01 24 F7
Last value is: F0 41 10 00 00 00 0E 12 19 70 2E 23 00 00 00 01 00 01 0C 05 13 F7
How can can i set this up to select from all of these the smartest (quickest) way possible?
bonus would be if i could use one knob to jump to discrete points on the list (kicks, snares etc) then use other controls to scan through from there, might that even be possible with two knobs now that im thinking?:thinking: i was just thinking that i would need 4 knobs to reach all 450 values, but less knobs would be great too! I am in over my head on this, so I really appreciate any help :slight_smile:
Well the attached would be a start with a single 7 bit encoder, although the precision will only select up to 127 sounds.
You could break 3 encoders up to set up three 7 bit values which looks like what you need for your project. I included rules for Roland checksum as well as scaling the CC to a 21 bit value.
Roland JD-Xi - Drum Select-Example-2026-10-21.bmtp (2.8 KB)
