I’m looking to convert a MIDI CC message from 5-pin DIN to a TCP or UDP string. Is this possible with MIDI translator pro or Bome Network?
Using the Translator Pro trial software, I am not seeing a clear option for this in the “Outgoing” section. Any guidance would be appreciated!
Bome MIDI Translator Pro or Bome Network Pro do not do any conversion to MIDI or UDP. BomeBox, however can send raw MIDI TCP using the Allen and Heath Protocol.
A could of ideas without BomeBox:
1 ) Use Puredata and send MIDI to it to have it convert to UPD or TCP
2 ) See if you can do what you want with Central Control Studio. I think it has a TCP output option.
Thank you Steve!
