I cannot for the life of me figure out why i cannot get bomes to record properly in FL studio. Midi triggering works perfectly.... the problem is it does not recognize it when recording for some reason.
see my screenshot video... sorry for no audio because its the trial version of the screencast software. in the video im hitting the Z button on my typing keyboard...as you can see midi triggering is working. it even works DURING recording, but for some reason it doesn't record the recorded info. https://www.youtube.com/watch?v=d9TIH8hiFrw
Anybody have any idea on how to fix this? I can provide any settings im using. I've tried a lot.
I can see that it appears not to be working but I have no idea what MIDI you are sending to start/stop recording. Can you post you Bome Project File and perhaps a log of the MIDI messages you are sending to FL Studio to start and stop the recording process?
thank you for the fast reply. here is the bomes file https://www.mediafire.com/file/2sgpb715jdyxjrl/typingmpc.bmtp/file
to be clear… im not referring to start/stop midi functionality. i’m saying that fl studio will not record the midi notes information even though it recognizes the midi info when its recording and not recording. the midi information is never printed/recorded during/after the recording process.
im not sure how to get a midi log. let me know if you definitely need that and i will try to figure it out.
Looking at your project file, it appears you have not defined any MIDI output ports for your MIDI messages. Maybe that is the problem as if you have not defined output ports from MT Pro, how would FL Studio be able to recognize MIDI input?
you mean on my midi settings in fl studio? yeah i noticed on the screencast video i didnt select bomes for the midi output…. trust me, i’ve tried ALL midi output settings available. Its the same when I select the correct outport ports.
Unless you have hard advice on settings i should try that i have not tried already.. I will try them, gladly.
Well I’m not an expert in FL Studio so if you are confirming you are getting MIDI information in FL studio from MT Pro but are note getting FL Studio to record it, then this is really a FL Studio question. In MT Pro, if you can turn on logging and check MIDI out while you are trying to record the MIDI, I could at least see whether MT Pro is sending MIDI and to which port. You could then show me how you have set up FL Studio for MIDI IN and I could confirm if you are listening to the correct MIDI port.
As far as FL Studio recording MIDI, I would think that the notes would get recording on a MIDI track in FL Studio and that MIDI track would then be forwarded to the appropriate instrument audio track for final audio rendering.
Hi, I’ve included screen shots on how I think FL Studio should be set up as well as MT Pro. Make sure in FL Studio you set for the proper MIDI port BMT 1 with the proper MIDI performance channel (MIDI CH1).
In MT Pro set output to Bome MIDI Translator Virtual Port 1 (which maps to BMT 1 on FL Studio if shortnames are selected in MT Pro options.
I noticed in your project file, you have nothing that sends any note-off messages.
I have yet to see an example of your outgoing log from MT Pro. Not much I can do from here until I see that.
I tested the record funtion on FL studio with these setting on my Windows PC and everything worked as expected (including no not-off messages coming through).
IN 0.0: Keystroke: Z
OUT 0.0: MIDI 90 24 7A
theres the log.
what is BMT1 controller? I don’t have that setting. Edit: nm mine says \”Bomes Midi Translator 1\”
you tested and recording works for you? this is so frustrating… why does it work but it won’t record? im trying everything on two different versions of FL even.
here’s another video: https://www.youtube.com/watch?v=0dpS5l1N8Bo
Hi, thanks for this! At 0:33 of your video, I don’t see that you have checked a MIDI channel for Performance (on your version of FL it looks like it is called “Playlist Live”. Set it for MIDI channel 1. Maybe that is it?
OK, I actually unset that and it still worked. Maybe you have some other MIDI application that is also trying to access that same MIDI port? Can you see MIDI coming in if you go to settings debug in FL Studio?
not seeing anything for midi in debug. the weird thing is that when i plug in a usb midi controller, they record just fine. it will also record if use the typing keyboard setting on fl. i should\’ve showed that in the video. extremely frustrating.
I you are not seeing anything in on MIDI debug, then it is likely that some other application is already using the input port BMT 1 (Bome MIDI Translator Virtual One). Please ensure that there are no other MIDI enabled applications running besides MT Pro and FL Studio. Did you see the video I posted?
You are running on Windows platform, right?
Also, make sure that MT Pro is not in current focus when hitting keys on your computer keyboard, otherwise by default they will be suppressed by MT Pro.
