Hi Steve
I just purchased a Bome Box and am messing around with the trial of Midi Translator Pro.
I’d like to simplify my workflow for converting Midi Note messages to CC messages and have a few questions…
- I’m using an effects unit that has 4 presets within it’s effect blocks that can be accessed via Midi CC. To access each preset of the effect you just send the unit a value of 1-4 on the same CC, with a value of 1 selecting preset 1 and 2 selecting preset 2 etc.
I’d like to toggle instantly between each preset by Midi Note to CC conversion, so that C4 selects preset 1, C#4 selects preset 2, D4 selects preset 3, Eb4 selects preset 4. Then on the next effect block on a different CC, E4 selects preset 1, F4 selects preset 2, F#4 selects preset 3 etc.
I’d like to do this for 3 effects blocks which would be an entire octave of Midi note to CC translations (ie 12 notes)
Is there a fast way to programme this so that the behaviour is an instant toggle between effects presets? I’m guessing i need to make some Note Off to CC translations in addition to the Note On to CC translations.
In addition to that, what would be the right translation to then ensure that in fact any octave of each Midi Note performs the same CC translation? So for example, i’d want not only C4 to send that CC command but also all other octaves of C (C3,C4,C1 etc).
I also have another scenario i’d like to programme where instead of toggling between presets within effects, i simply want one Midi Note to engage one effect, and another Midi Note to engage another effect etc. So far i can make this happen by making the following translations:
Midi Note On to CC (with the CC’s value at 127 to activate effect)
Midi Note Off to CC (with the CC’s value at 0 to bypass the effect)
Is there a faster way to do this all in one translation per Midi Note to avoid having to do 2 x translations per Midi Note?
I also noticed the following behavior with Midi Translator Pro. When using it between two devices via USB or Firewire, the Note to CC is instant. When using it via wifi, connected to the Bome Box with the Bome Box placed between the two devices instead of the laptop, there is a lot of latency. Am i correct in thinking that if i purchase the full version of MTP that my projects uploaded to the Bome Box will then run with zero latency as they do on my Mac?
