I’m using a BomeBox MIDI Hub to send MIDI commands from a Mackie Control Universal Pro USB remote from a local thinclient to a Windows server in the same LAN to control an audio software.
With the windows firewall disabled, it works fine both ways, MIDI commands are well received by the server and the usb remote.
But for safety reasons, I would like to set it up with an enabled firewall but couldn’t make it work.
Bomebox softwares are authorized in the firewall configurations but the MIDI device is not seen on the Windows server.
Is there a list of ports that I would need to open to make Bomebox works through firewall ?
