Hello, I have searched and did not find and answer to my question… Is there a way to do a basic midi filter to stop all data from a certain midi channel from passing thru? I must be missing something. Any help would be much appreciated. What I am looking to do is to stop all data from channels 1 & 2 from passing thru MTP (or BomeBox).
Created 2 aliases “My Source” and “My Destination” and then assigned them the MIDI ports on my system. You will need to reassign them to your actual devices.
Setup a MIDI thru path for the assigned aliases.
Set up 2 translators. One for any 2 byte incoming message oo pp. The other for any 3 byte incoming message oo pp qq . Set outgoing action as “None”
In rules of each translator, determine the incoming MIDI channel and if it is 0 or 1 (< 2) executed the outgoing action of None. Since Swallow is also set, then these messages, will not pass to the MIDI thru route when executed. If I skip the outgoing action then, swallow is not in effect and the messages go through the default MIDI thru route.
You can also do this on BomeBox if you upload the files there and assign the destination ports accordingly. The BomeBox can only do this through a signed MT Pro project file.
