On my PC (windows 10), midi-to-mouse control (using the first option to add to the horizontal or vertical position), the cursor immediately jumps to the left edge of the left screen. (I use the right display as the main screen).
It does work as expected on OSX, no jumping there.But I want to use it on the windows machine as well.
I can’t use the other option (absolute position) since it seems MT Pro does not have a variable storing where the cursor is (annoyingly, MT Pro does have a function to manually click on a point on the screen, and then it displays that x-y value, so the basic function for this seems to be there). Or is there a variable that always has the x-y value? MT Pro can also place the cursor at a specified x-y position. So it would work (I assume) if I had a variable with the current x-y when I do the increment.
Is this a known bug?
Best
Jonas
