Hello, i recently upgraded my trial version of the MIDI translator classic to the full version. Unfortunatelyn now when i open the program it immedeatley closes. Is there a way to solve this?
The most likely cause that your startup options has it start minimized
If this is the case, you will find an icon in the menu tray. You can right click on it and then press left click on ‘Show’.
Then change your option settings if you don’t want it to start this way.
