Hello Florian and the whole MTP gang!
With my current setup I use 2 monitors, one 4k and one 1920 x 1080 that happens to be my main monitor lying in front of me (see attached JPG - this is how Windows sees them both). When I create an Outgoing Mouse Position and use the Capture ... to find the X-Y of my cursor that is on the 4k monitor the readout is correct (for example: X 100, Y -500) and it looks like the coordinates are captured correctly. So far so good. As soon as I send the MIDI massage that suppose to trigger the Outgoing Mouse Position my cursor moves only to the border of the 1920 x 1080 screen and is not reaching the negative pixel value - for example instead of Y -500 px it only goes to Y 0 px. Is there a workaround or a setting somewhere that will allow me to reach the other monitor or am I only limited to the screen that is currently selected as the Main Monitor (the 1920 x 1080 in this example)??? I did some tests and selected the 4k monitor as my main monitor in the Windows settings and the smaller one as my secondary monitor and I could reach all the pixels from the 4k monitor but none from the 1920 x 1080 one.
Is this so by design or am I missing some setting or a trick here?
Thank you for any tips!
Cheers!
