Hi, In short I wonder if I’m missing something with MTP’s limit of 9 virtual ports, as I’m seemingly able to create an infinite amount in Bome Network.
My current use case is taking MIDI controller input/outputs and switching routing between different aliases/virtual ports. Currently this is between mac and iPad, in future many more. For simplicity’s sake I’m using one alias/virtual port per controller/program and can only create the amount of virtual ports necessary in Bome Network.
Yes Bome MIDI Translator Pro has 9 virtual input and 9 virtual output ports (for a total of 18 ports)
At this point, if you need more virtual ports, you would need to use Bome Unlimited Named Ports which is an addon to Bome Network (whether you use the networking features or not).
With Bome Network, you would need to create one virtual port for each input and one virtual port for each output needed. You would then need to set up routing for the virtual ports for instance ‘IN: My Port → OUT:MyPort’ to create a pipe between the endpoints.
I know that there have been requests in the past for more virtual ports in Bome MIDI Translator Pro itself (before Bome Network existed), but am not sure of the status of the request. I will check and see if it is still planned.
I agree that changing Unlimited Named Virtual Port routing, without the current Bome Network User Interface would be nice. I think it might be teed up for a future enhancement.
There is a trigger for port open, port closed, port available. Any supported outgoing action will work. There are outgoing actions to create routes, delete routes, enable routes and disable routes in MT Pro.
Check out the new ‘Perform’ rule released earlier this week.
I’ll ensure your requests are reviewed.
