Midi Translator pro won't start Mac os 14 Sonoma
Hi, i just got MTP installed, but it wouldnt close the main window on exit. I also had the problem that midi to key command just wouldnt work. Now i cant even restart the program, wont open a window, any idea? thanks so much, uwe
I’m sorry for your problems. Is your Mac Intel or Silicon based?
We are seeing some people experiencing problems on Silicon right now and we should be able to better pinpoint the issue with a dump file. It would help if you could follow these procedures.
