I have this set up in Bome Classic - now moving to mac and already have putchased Bome Pro. How do I make script to accept ANY midi Note and output Velocity as keystroke + ENTER?
I did 127 lines in classic manually - now it seems that there might be better way doing it?
Assuming you want each note to have a different computer keystroke, you will have to have each translator output the specific keystroke you want for each of the 128 different notes. This would be 128 separate translators.
OK, yes this is quite different and can be done with less translators.
In the example below I use “Perform” which is available as of Bome MIDI Translator Pro 1.9.0 to handle this.
Translator 0.0 takes the note-on message as a trigger and captures the velocity into the global variable “ga”.
It then calls translator 0.1 which does first focuses the target application (translator 0.2) and then does the character conversion.
A combination of perform “Digit” and perform “Character” are called with parameters to output each desired character. The keystrokes are all contained in preset 1 which contain the 10 digits needed (0-9) an characters space CR and LF.
Most of the heavy lifting is done in the rules of translator 1.1. It is written to accept values up to 9999 and can be used by other triggers than notes which would only allow up to 127. Leading zeros are skipped in the rules. The parameters passed are the desired keystroke and delay.
Perform "Focus"
//delay increment
ss=5
rr=ss
//1000's
pp=ga%10000
pp=pp/1000
//skip leading zeros
if ga<1000 then skip next rule
Perform "Digit",pp,rr
rr=rr+ss
//100's
pp=ga%1000
pp=pp/100
// skip leading zeros
if ga<100 then skip next rule
rr=rr+ss
//10's
pp=ga%100
pp=pp/10
if ga<10 then skip next rule
Perform "Digit", pp, rr
rr=rr+ss
//1's
pp=ga%10
rr=rr+ss
Perform "Character",13,rr
