hello,
can someone help me with my akai midimix?
i’m trying to get led feedback on my buttons.
found some presets but i have no clue how to do so.
i try that when i move fader one that the mute button blinks three times and then stays on until fader one is off and if mute is pressed the same should happen.
And the rec button should light up only when its pressed.
same with the page buttons.
What you are asking would require some programming in GrandMA if you want your LED state to truly depict what GrandMA is doing. GrandMA has the capability to do LUA scripting which is beyond the scope of what we support on this forum. Also I believe GrandMA has a “midinote” command, that you could use but probably not to the level of what you are trying to achieve.
With that said, if you want to “guess” what GrandMA is doing by incoming MIDI messages from your MIDIMIX, we could indeed program LED behavior as you wish within Bome MIDI Translator Pro. It just may or may not be an accurate representation of what is happening in GrandMA.
If this is what you want, I can provide an example of what you describe.
Let me know.
