I’m able to get mouse control from Maschine’s rotary encoders if I set them to relative. (using the preset found here
If I set the encoder to absolute, they behave strangely, changing direction only when the CC value crosses 64.
I’d like to use the fader on a Korg Nanokontrol to control mouse movement but I get the same “absolute” behaviour described above? There is no “relative” option for the Nanokontrol faders or knobs. Is there a way around this?
not the most elegant, but it worked. i used loop midi to send gc out then back in to a translator for the mouse movement. since it’s a mouse, I don’t need the calibration so I may delete part.
