im trying to grab focus of the VST preset menus in the reaper daw… i havent been able to find within reaper a script/action that will grab the focus of the internal VST-preset menu thus highlighting the presets sub-menus etc etc
can someone point me to script that will essentially achieve the following:
1 position the the mouse pointer(with a midi button)
2 then allow me to move the mouse pointer X amount of pixels to the left or right(with an encoder)
also with another encoder or alternatively with a held down(or toggle) midi-button & same encoder
3 then allow me to move the mouse pointer X amount of pixels up or down(with an encoder)
the encoder type on my maschine jam uses both absolute and relative in midi-mode
any help in this would be great!!
thanks in advance!!
