I saw the tutorial on how to do it with knobs, but that doesn’t help. Would love to go full keyboard and play overwatch on my stream. Any help is appreciated ![]()
I’m not sure what you are trying to accomplish. Please provide a link to the tutorial or describe in more detail what you are looking for.
The knob tutorial probably uses CC messages; piano keys send Note On/Note Off, so map those instead. In Bome MIDI Translator Pro, create one translator per movement key: incoming Note On for that note (velocity greater than 0) → outgoing Key Down for W/A/S/D; incoming Note Off for the same note → outgoing Key Up. Some controllers send Note On with velocity 0 as note-off, so handle that case too. Make sure the game has focus and the outgoing action is keyboard output, not MIDI.
