Hi, Lines 38 and 39 is a 14 bit CC for CC0 on MIDI CH1. You could set up an incoming trigger as such and capture the incoming message that way. Lines 36 and 37 are 7 bit CC messages CC7 on MIDI CH1 and CC11 on MIDI CH 1 repectively. The reset are SysEX messages.
MIDI IN and OUT will only show raw MIDI. You should be able to capture in non-raw MIDI form by clicking “capture” within a translator input box and then pick the message you want.
My first Problem is in the capture window i have only raw.
Sorry but im a musician
When i try to write it in this Format
F0 43 10 4C 02 01 qq rr F7
is this Hex?
So this is Msb0 Lsb0
F0 43 10 4C 02 01 00 00 F7?
And this is Msb0 lsb1
F0 43 10 4C 02 01 00 01 F7?
i dont understand this
Blockquote
To combine them into a single value you would use a rule like this.
// shift bits up 7 bits into MSB and put in variable tt
tt=qq<<7
// or with lsb
tt=tt|rr
// tt now contains the 14 bit value
Yes, this is hexadecimal. This is a SysEX message (anything that starts with F0 and end with F7), and each vendor has it’s own method for how these work so there is no human translation for SysEx messages. You have to look at the vendor MIDI implementation document (if they have one) to understand what is happening.
These look like Yamaha proprietary SysEx messages. You would need to look into their documentation to see what they mean. The second byte is the manufacturer assigned. See this. I did a google search on F0 43 and it took me to a Yamaha resource site.
This is a 14 bit CC message which is also considered to be 2 7 bit CC messages.
For first 3 bytes
B - Means it is a CC message
0 - Means MIDI CH 1 (MIDI channels 1-16 are 0-F)
00 - CC number 0
00 - Value 0
For second 3 bytes
20 - CC number 32 (20 Hex)
00 - Value 0
All MIDI message begin with a control byte (with bit 7 high)
8 - Note Off
9 - Note ON
A - Channel Aftertouch
B - CC
C - Program Change
D - Polyphonic Aftertouch
E - Pitch Bend
F - Various
You can use a programmers calculator to convert Hex to decimal. Or ask Goole
“What is hex b0 in decimal” and you will likely get returned to a result with various hex calculators. Windows Calculator has an option to set it as a “Programmers Calculator” which will also do that for you.
My Yamaha Keybord only send MSB and LSB as CC#0 with value and CC#32 with Value.
It will not send any Sysex.
So how can i add 2 Controllers?
In ur first answer you said click on the message you want, when i click i have 1 controller, Msb or Lsb.
how can i add the second one?
Perhaps you can tell me what outgoing action you want to take when receiving these messages. In your case, these would be bank change messages coming in from your keyboard.
Do you want to execute a file on just a certain bank change number or any bank change number? Do you want to execute different files depending on which bank change you are sending?
OK, so with MSB-LSB you have a combination of 16,384 Banks. Each Bank can have up to 128 Program changes. This would be for each available MIDI channel Usually with MIDI nothing happens until the program change occurs. You could set it up so the CC Bank changes just capture the current Bank in a global variable and then have translators that execute files based on the global variable (current bank) and the program change number.
The attached file will do this.
The first translator sets the current bank number in the global variable GA when the bank change message arrives.
// get bank number into ga
tt=qq<<7
tt=tt|rr
ga=tt
The second translator opens Windows Notepad with the name program%pp%.txt where %pp% is the program number so program1.txt program2.txt etc. but first it checks to see if the current bank number is 0 in the rule. If the current bank number is not 0, nothing happens.
//check if it is bank 0
if ga!=0 then exit rules, skip Outgoing Action
The outgoing action is this. If you are Mac, it will be quite different so this is for example only. You could open a different Ableton Live Project File depending on the incoming bank. Keep in mind the old project file may or may not stay there. It really depends on how your application manages multiple instances. I’m not sure if Ableton Live closes an existing project file when you open a new one.
Here is the example Bome MIDI Translator Project file.
Ableton always ask me to stop before loading another Track.
Is it possible to send a midi note before i execute?
I hope you understand what i mean.
When i send the LSB and MSB ableton loads a file. But i need to send a stop command to ableton a second before i execute the file. I can send it through the IAC Driver on my mac, but what do i have to do in Transaltor? Ableton stops when Note G8 is send on Midi Channel 16.
I added another translator to send a note, then put a 50ms delay on the translator to open the file.
I also set up MIDI aliases as follows. You will need to assign them to the physical ports that you use. You could certainly use an IAC port if you want.
i had it work but with more problems, i come back later,
my question now, how can i get back the “select midi device” Dialog Box?
EDIT:
Following Problem, the Stop only works with the first file.
I attached what i´ve done.
Do i need the stop ableton for every file? Test.bmtp (2.0 KB)
EDIT 2:
I found that i need to add the stop ableton for every file. Right?
one more question. Is it possible to change all path at once?
I added my bmtp file so u can see (perhaps) what i mean.
I start files out of the folder Live. But sometimes i need to start out of the folder alone.
So i need to change only the folder Live to alone.
I dont think its possible but perhaps???
You will need translators set to the absolute path of the executable. If you want to change this in different circumstances I recommend that you create a new preset with all of the translators with the alternate path and then set up a way to switch presets having one only open. One with the folder “Live” and the other with the folder “alone” on the path.
