MT Pro compatibility with Mac OS Sequoia
Before upgrading - please can I check that MT Pro is running ok with Sequoia?
Thank you!
Don’t know. Will check into it.
Thank you!:pray:
Also, does the existing MTPlayer app work okay as well?
We have not run any official tests on Sequoia. That takes a little while, usually. For important computers, we recommend waiting a few months before upgrading to the latest version of MacOS.
Found this online, but can’t find an attribution for it: does anyone have any more info? The need to update is becoming a bit more urgent now:
*Bome MIDI Translator Pro is not compatible with Sequoia, but it is compatible with Windows and macOS
This is definitely not a statement from us, and it does not make much sense, because Sequoia is macOS, too.
Please note the difference of being officially supported, and it just runs. Our software has always generally worked on new versions of macOS, and mostly, Apple maintains backwards compatibility well. So there is no reason why MT Pro would not run on Sequoia. Of course, we’re doing in-house testing, but we still always wait a few months before declaring official compatibility. That strategy has proven to be beneficial for our users and for us.
Having said that, we’ve just made support for macOS 15 (Sequoia) official.
:grinning:
Excellent news - well done all!
