MTP - won't open
Hi I just bought this app like a week ago. Installed it used it - made a mapping. Now I can’t open it. Just shuts down when i press the app icon!? To begin with it was only some times i couldn’t open - now it is all the time.
I have checked security setting on the mac and allowed what possible for MTP.
Also tried reinstall MTP - no luck
I’m on Monterey - by the way…
Please help
See if you have minimized at startup set. If you do, MT Pro will open but be in the menu tray.
Hi Steve
Thank you for quick response unfortunately that is not the problem. After i wrote yesterday it suddently opened when i tried. But today started computer no other apps running, same problem again. I try to open 30 times, gets shut down emediately. really wierd.
Any ideas on what to do?
Probably solved - okay so I just had the idea of running Maintenance. An app that fixes app permissions and cleans you mac. It seems it solved the problem.
OK, this is good. If it happens again, please send us a dump file so that we can take a look. Instructions on how to do that are here.
