Multiport MIDI Interface with BOMEBOX
Is the MOTO MIcroLite 5x5 Midi Interface compatible with BOMEBOX.
Are other multi port that is ?
Thanks.
It probably won’t work because it doesn’t claim Class Compliance and requires MOTO software drivers which are only available on Mac and Windows PC. You should probably check with MOTU to see if the device is USB class compliant but I suspect not.
