Newbie Question. ‘Port pending”
For some reason my Bome virtual port has just started showing “pending error”
Sorry for a beginner question :thinking:
Hi, you must be on Windows then. This is usually because another MIDI application is holding the port only and on Windows only 1 device or application can access a given MIDI port. Most applications allow you to deselect devices which will allow Bome MIDI Translator Pro to open the port. If not, then close the other MIDI application open Bome MIDI Translator Pro first, so that it retains control of the port.
Hey thanks mate. That was it👍
