I don’t have my A&H qu mixer in MIDI router list
Everthing just working fine in Bomebox but i can’t make it see in projects MIDI translator…
To use the A&H Mixer you need to connect to a BomeBox and set it up to recognize it. You can then use Remote MIDI Direct to see it on your PC.
Alternately, I believe A&H has a tool that you can use on a Windows PC that can convert A&H Network Protocol to MIDI. I believe it is called Allen *& Heath MIDI Control.
Ok, i’v found Remote MIDI Direct
Tnx
