On startup of Bome MT classic I am getting a message saying there is not enough memory. Even after restarting my computer. See pictures.
Also I am unable to assign key combinations in the 'Physical Keys' output section in MT Pro, I hold e.g. Shift and then A and the two are not combined whereas they are in MT Classic.
Hi, in MT Classic, a not enough memory error is usually the message you get if some other application is already accessing the MIDI port you are trying to use. Please be sure that other MIDI related applications are note already accessing that port/device.
Key combinations do work in MT Pro. If you hold shift and A it will probably show a capital A in MT Pro where an unshifted A will show a lower case "a". Other combinations like Alt, Control, and Windows should show these functions as Alt(a) Cntrl(A) or Win(A) or something like that.
Thanks for the mega quick reply. I have a video here of what is happening in MT Pro when I try and assign key combinations to the output 'Physical Key' field. It only allows for one key at a time.
https://youtu.be/vHmFfGbZ9cM
The memory thing is resolved as I discovered that I had multiple instances of MT Classic open simultaneously.
The video shows as private so I cannot view it. If you post your project file and point me to the translator in question, I can try and help from there.
