Is this on your APC-40 or your MIDIMix? If on your APC-40, make sure you put it in mode 2 first to ensure the buttons are in momentary mode and that it recognizes MIDI commands coming back for LED feedback.
In either case, I believe both controllers need note-on at velocity 0 to turn off the LEDs. So once in momentary mode, both controllers should work the same way.
An example of toggling an LED would be
Incoming: Raw MIDI 90 33 7F on APC-40
// toggle the value of ga
ga=ga^1
qq=0
if ga==1 then qq=127
Outgoing: Raw MIDI 90 33 qq to APC-40
Of course you would need a different global variable for each LED (unless you use the bitmapping technique we discussed in earlier conversations).
I found another solution with the example APC-40-Knob memory and now it works.
I have the MK II in Mode 2 and work since you told me, only in Mode 2.
With the rules I couldn`t resolve the thing. I have copy and paste from the APC-40-Knob Memory the LED Feedback and Channel Switcher. Only with these 2 presets it works. Without the setted variables on preset LED feedback didn`t get any LED feedback.
With the rules, you wrote above didn`t run the LEDs.
In Mode 2 the MK II has a clearly LED board. Nothing reacts from the LEDs, if I press buttons or rotate knobs. So I have to programm everything from the start, to get working the LEDs.
Right, in mode 2 you will have to do all LED feedback from the Application or Bome.
If you can post an example project file of what you have that is not working, maybe I can show you where the issues are.
1) At the preset level you need to override the default output port (which is currently Application->Bome MIDI Translator 1. Change it to APC40 Mkii. Click on the preset on the left and then on the right click specific ports and select APC40 mkii. I don’t think you want LED control to go to your Application.
2) I suspect you want to toggle the outgoing value between 0 and 127 (since this LED is not multi-color). Instead of outputing value of oo pp qq. use ga for translator 1, gb for translator 2 and gc for translator 3. Also change it to toggle ga, gb, or gc respectively.
Yes! It works perfectly!
Thank you for this solution.
Now I have try to do this with the multicolor pads with “note on/note off” it works perfect too!
Example: Press Pad CC32 – LED goes on, press Pad CC32 again LED goes off.
I couldn`t solve this till now.
Only with preset change Note on/Note off, what was very big preset project for this…
