Hello! It’s been awhile since I last posted. Having BOME MIDI Translator Pro for years, now, finally got a BomeBox thus testing a couple of projects to load onto the BomeBox.
I ran into an issue with this particular project where I am using SysEx messages to flash the LEDs on the Track Focus & Track Control pads of the Launch Control XL. It is basically having 3 Dials also start flashing upon enabling 3 pads in the Track Focus strip of pads. The Dials in question are located on the 3rd column (from left to right) of the Dials zone.
The project initializes (via SysEx using the ESC key) with a change of Template selected in the INIT Rules, followed by 2 SysEx messages to turn Off the flashing LEDs function (to ensure it clears previous flashing), then, the SysEx message to turn back On the flashing capability.
The pads on the Track Focus & Track Control work as they should, however on the output, for some reason it is also enabling those particular dials.
If I change the LED channel (on the specific Dials in question) to 2 (versus 1), then, the Dials LEDs do not turn On/flash.
Below is a pic of the settings per Components (Novation SW editor), along with the BOME file under test.
Some Data:
- Pads (Template 2, Channel 1) are set to A1-A#1-B1 (pads 2-3-4 of Track Focus lane), which, result in Decimal values of 45-46-47 (Hex 2D-2E-2F)
- Dials CC Values (15-31-51 [Hex 0F-1F-33]), on MIDI channel 1 for CC, and, channel 1 for LEDs. Dials is the only section that one enables the channel independently for Dial CC rotation versus LEDs.
So, why is there an interaction between the Pads and Dials (when both set to channel 1), on these particular (specific) locations? The rest of pads/dials do not behave in such a way.
Looking forward to some feedback on this “glitch”. Thank you!
Luis
TrackFocusControl_Flashing.bmtp (2.0 KB)
