Hi there!
DAW is Cubase 11 Pro.
Controller is Novaton Remote SL mkii 49 in Automap mode.
I’m not using Novation’s old dreaded Automap server software so I’m writing my own custom “surface” for Novation Automap using BMTP and old Novation’s Programmers Guide. I have some success at getting full LED feedback with transport controls and Cubase’s Generic Remote (transmit option enabled), LCD display messages reacting and full feedback with Track Quick Controls as well.
The thing is that I want to control VST parameters in a better way using endless encoders and seeing parameter names on LCD. Unfortunately, Cubase’s Track Quick Controls are not allowing me to send names of VST’s parameters to LCD display, Cubase is just sending actual values of controllable parameters. So I’ve found that MCU could be the solution for my needs since Cubase supports MCU usage. I’ve found some docs (MCU MIDI map, Logic Control guide, some others), but it’s just like diving into the ocean - nothing seems to be understandable at first sight.
So, several questions about MCU:
- So I’ve added Mackie Control to Cubase. While I’m adding any plugin in project with Mackie Control being active Cubase sends a LOT of info to controller. I guess that info could contain plugin’s name (is it ASCII though?) which could be used for sending it to display.
- Looks like real MCU needs some kind of message to be sent to DAW for activating VST parameter controlling (AFAIK it’s called “Assignment”, probably). Seems to be the midi note, but I’m definitely doing it wrong - nothing happens.
- Is it possible to control more than 8 knobs/encoders/on-off buttons with MCU?
- How do I “decrypt” display messages that are sent from DAW to real MCU? Is it still ASCII?
Starting something new is never an easy thing thus you must start with something little. What angle should I start searching from?
Sorry for my English. Thank you
